So.....lol (adding CC stalks)
Have swapped the stalks over for cruise control stalks, the part numbers were a direct match that I could see on the part.
Have 4 codes not clearing on my cheapy scanner. And no steering wheel controls at all... which is odd as everything is plugged in I believe. Getting it scanned with VCDS tomorrow
Has the car got cruise control? Or were you hoping the stalk would give you cruise control? I ask because if it's the latter then it'll.nerd to be coded to the car to make it work.
Hi you lost the coding for the slip ring/ squib ring thats why you have no steering wheel functions , therefore it will need re coding.
Fair. Have abandoned it for now. But the refund will likely sit and go towards someone like hazzydays who can get it all sorted on the spot. It can wait until next year now lol
