Jerseycar Posted March 16 Posted March 16 A3 (8PA) with an intermittent, reverse gear selection issue, usually occurs when the engine is warm. Current solution is to put it in park, switch the engine off and restart. Had it checked out by the Audi specialists who advised there were no fault codes. A bit stuck, can't decide whether it's likely to be a ECU issue or mechanical, gearbox/linkage issue. Has anyone come across this issue or can give any advice what its likely to be ??
Steve Q Posted March 16 Posted March 16 Could definitely be an issue with the megatronics. When was the gearbox oil last changed as this can sometimes cause selector issues if it's old oil.
sixgood4 Posted March 18 Posted March 18 had similar isssue with my a3 1.6 tdi 2016 auto 7 speed , had gear box oil /filter changed fixed the issue .
Jerseycar Posted March 19 Author Posted March 19 Suspect it's something more 'in depth' but making a decision whether to go down the electronics or mechanical investigation is going to be expensive and might find a solution! I do think, it's likely that there are more cars out there with the problem, just finding out solutions worked.
cliffcoggin Posted March 19 Posted March 19 3 hours ago, Jerseycar said: I do think, it's likely that there are more cars out there with the problem, just finding out solutions worked. Even that could be an expensive waste of money. Just because another car has the same symptoms as yours does not mean the cause or its solution is the same as yours. Diagnosis is the key to getting a repair at the lowest cost. If your current Audi specialist can not find the problem, find another specialist.
Jerseycar Posted March 20 Author Posted March 20 don't know, but thanks will check it out to see if it was
wezar Posted 16 hours ago Posted 16 hours ago Hi guys I have audi a3 2008 automatic mine is doing the same i done a gear oil change still doing it all other gears fine just reverse then turn engine off then on gear goes in we are all confused
Steve Q Posted 4 hours ago Posted 4 hours ago 11 hours ago, wezar said: Hi guys I have audi a3 2008 automatic mine is doing the same i done a gear oil change still doing it all other gears fine just reverse then turn engine off then on gear goes in we are all confused I'd recommend a diagnostic check to see if any fault codes flag up 1
Jerseycar Posted 3 hours ago Author Posted 3 hours ago Would be good to know if you do get a diagnostic check done if it does flag any faults, we have had the same done twice on our car and no faults found, we have been recommended to get a recon gearbox for the car ?? 1
wezar Posted 1 hour ago Posted 1 hour ago 1 hour ago, Jerseycar said: Would be good to know if you do get a diagnostic check done if it does flag any faults, we have had the same done twice on our car and no faults found, we have been recommended to get a recon gearbox for the car ?? I had mine plugged it don't really come up with much they are saying it's a electrical fault between gearbox and brain of car
