Hi. I’m new to the forum and wondered if anybody has had the same issue. It’s a 23 build year and recently, when in intelligent mode, the car doesn’t shut off the petrol engine, which is resulting in sub 20mpg. It’s intermittent but for sure, it’s definitely not right. It’s booked in with Audi in a few days. Any advice would be appreciated. Thanks.
I'd recommend a diagnostic check to see if any fault codes flag up. As this is under Audi warranty I'd get it booked in asap.
Thanks, Steve,
I’m hopeful that they do find a fault when they plug it in, as there are no fault  messages in the MMI, which I find strange. I’ll update post following Monday’s visit to Audi.
Welcome Antonio,
Regrettably Andrew never did return to let the forum know how the issue was resolved. Let’s hope he does now, but if not, you could send him a PM and hope for a response.
Regards,
Posted (edited)
23 minutes ago, Magnet said:
Welcome Antonio,
Regards,
Thank you very much for your reply.
Audi dealership is trying to solve this problem since october 2023. After the diagnosis they find error P044100 - EVAP emission incorrect. The solution was to change N80 valve, but the problem came back!  Every 2000km, more or less, the problem returns and i have to stop  the car, shut off engine and restart the car so that the system works normally again. I went back to the workshop more than 10 times and they changed practically everything in the EVAP system, but without success. Next appointment at the dealership will be on the 11th. I'm curious about what they'll replace this time...
Edited by MiguelP
Many thanks Antonio,
If we haven’t received a response from Andrew by the end of tomorrow, I’ll send him a PM for you, and hopefully post a response.
Regards,
