No idea about those roof lining buttons, but I’ll bet it will look horrendous by the time you’re finished.
The only way to fix properly is to remove, strip off the old headlining, and use new OE VAG roof lining with a suitable contact adhesive. Tools wise, long handled torx screwdrivers, and this special tool for interior grab handles. https://vw.snapon.com/SpecialToolsDetail.aspx?itemId=38730184
There’s curtain airbags in there, so disconnect battery and leave for 30 mins. If this is a B6 Avant, headlining can come out via the tailgate.
Usual electric connections as sun-visors, central convenience lighting, etc. If there’s a sunroof, then the panel detaches around it with metal clips.
Like a '70s hot rod mate!
I don't want the expense of removing the rear window to get to the roof lining. Nor did I want your opinion on what it might look like. I just needed to know if anyone had done this type of fix previously.
That's fair enough. This is a forum, so you're going to get different opinions and using roof lining buttons in my opinion is a bodge, but each to their own.
Here's the process on a B6 saloon. Good news is rear window doesn't need to come out. Removing front seats would probably help. You also don't need that interior grab handle too, looks like B6 are screwed/bolted in.
Thank for the video, however, I am disabled and can't remove this myself. I had it costed at well over £500. So the buttons on a 22 year old car at less than £10 v £500 is a no brainer for me. I have seen pictures of vehicles other than Audi's with this fix, but can't seen to find out if it's possible to fit the screws into the roof shell e.g. if it's a cardboard composite or is it fiberglass.
