Jim Ridley Posted Saturday at 04:17 PM Posted Saturday at 04:17 PM Hi to you all would any of you guys have a link to or a sequence for Coding a Tow Bar to 2019 Avant using VCDS Thanks in advance Jim
Jim Ridley Posted 22 hours ago Author Posted 22 hours ago almost got it sorted just cannot access 13 Auto Dist Reg in VCDS the controller is not responding followed these instructions all of it worked but cannot access STG 13 Coding applies to Audi A6 C8 STG 19 > Installation List > "69 - Trailer/Anhänger" - Activate STG 01 > Coding > Byte 5 > Bit 4 "Trailer installed" - Activate STG 09 > Coding > Byte 13 > Bit 4 "Hitch ECU,installed" Activate STG 13 > Coding > Byte 3 > Bit 3 Activate STG 17 > Coding > Byte 14 > Bit 5 "Trailer, YES" Activate STG 46 > Coding > Byte 14 > Bit 6 "Trailer control unit, 0=not installed / 1=installed" Activate STG 6D > Coding > Byte 01 > Bit 7 "Trailer Recognition installed" - Activate STG A5 > Coding > Byte 14 > Bit 1 "FW_AAG,installed" Activate 1
Steve Q Posted 18 hours ago Posted 18 hours ago Glad you're nearly sorted. Sorry the last bit isn't working.
Jim Ridley Posted 2 hours ago Author Posted 2 hours ago Thank you mate ,after a bit more digging and a bit of a disagreement with a guy on VCDS it appears I dont have this module in the car so this I why I could not access it , STG 13 > Coding > Byte 3 > Bit 3 Activate refers too (auto distance regulation) =adaptive cruise control ,as I dont have this on the car I dont need this section so all sorted Cheers Jim
