regdp Posted Thursday at 11:16 AM Posted Thursday at 11:16 AM Hello, I'm new to the forum and seeking suggestions on how to identify a problem with my electric windows. Issue is that the windows move when I lower and raise the hood, but the multi switch on the driver's side does not work. I ordered a replacement switch from eBay and this also didn't work. I've investigated the wiring in the door hinge but there are no obvious breakages. I've heard that it could be a faulty window motor and have ordered a used replacement from eBay. It arrives tomorrow. If this doesn't solve the problem I'm not sure what to do next. Does anyone have any suggestions? Many thanks
Magnet Posted 19 hours ago Posted 19 hours ago Welcome Reg, and thanks for joining. To save you buying components in the hope the fault lies with them, have you tried measuring the voltage ( and earth continuity) at suspected components? That would be my plan of action - if it helps. Regards, Gareth.
cliffcoggin Posted 15 hours ago Posted 15 hours ago Reg. You have not said whether the window movement is random or erratic. Is it possible the windows actually need to move out of the way when the hood is raised and lowered?
Solution regdp Posted 12 hours ago Author Solution Posted 12 hours ago Thanks Gareth, You're spot on. The replacement window motor didn't solve the problem. However I decided to have a closer look and the wiring loom and found two wires with splits in the plastic coating. I repaired these with insulating tape and it's fixed! 2
Steve Q Posted 11 hours ago Posted 11 hours ago 29 minutes ago, regdp said: Thanks Gareth, You're spot on. The replacement window motor didn't solve the problem. However I decided to have a closer look and the wiring loom and found two wires with splits in the plastic coating. I repaired these with insulating tape and it's fixed! So glad you got sorted 🙂
cliffcoggin Posted 10 hours ago Posted 10 hours ago 2 hours ago, regdp said: found two wires with splits in the plastic coating. I repaired these with insulating tape and it's fixed! Was that damage within the rubber bellows between door and frame? If not, where was it?
regdp Posted 9 hours ago Author Posted 9 hours ago Yes it was, but I could only see the damaged wires once I pulled all the wires back through the door.
