water ingress
drivers foot well is damp just mainly the middle of the carpet sills is dry where bonnet pull is dry behind peddles is dry h put a watering can down scuttle panel drain water flew out of the bottom anyone got any ideas
think i have found out where my water ingress is coming from its washer fluid topped up 3 times today and dropped below the plastic strainer cup does the pipe run down the drivers side
13 minutes ago, Steve Q said:
Keep us posted on how you get on. Let's hope it is what you think and not a heater matrix. Is it losing coolant?
Hi will do it’s dry around tunnel/centre counsel screen wash is going down without using it filled it 3 times today and every time it’s been below the plastic cup strainer
Sounds like it's that then.
how is it entering the cars interior though?
