Glow plug issues p0671,2,3,4
I’ve changed the glow plugs, circuit open fault code still shows
Ive changed the glow plug module, codes still show
Ive changed the injector/glow plug wiring loom writhing the valve cover, codes still show
Recently i’ve been having trouble with my steering lock and ignition switch, can anyone help with my issue. Thankfully it’s hot out so my rough start isn’t terrible
Battery is all good 12.6 volts if i remember correct and 13+ when running
The steering draws power and causes a dip in rpm followed by a slight vibration, normal on some vehicles i believe but not feels somewhat severe
If that is a simple voltage reading on a multi meter it is inadequate to determine whether a battery is defective. Steve is referring to a professional battery test that imposes a heavy load on the battery to expose internal faults within the battery such as high resistance or sulphation of the electrodes.
Battery tested at quick fit and all good. What process of elimination would you recommend in regards the glow plugs as the eml is my main concern for MOT
Hi can you please publish the codes as this may well indicate what is going wrong, did you recode the glow plug module.
There must be sub codes in there somewhere.
