low fuel pressure
hi in need of some help i have been having  low fuel pressure at the rail  my mechanic as changed the sensors and i have also had a new high pressure fuel pump ,but still getting low fuel pressure , car goes into limp mode when i accelerate  , any help would be appreciated thanks
Edited by lippo54
hi  im in need of some help i have been having low fuel pressure at the rail my mechanic as changed the sensors and i have also had a new high pressure fuel pump ,but still getting low fuel pressure , car goes into limp mode when i accelerate , any help would be appreciated thanks
hi thanks for the reply the fault code is p0087
That code is definitely low fuel pressure but being as you  have already replaced the HPFP the only other thing it can be is the low pressure pump in the fuel tank under the back seat its a common problem as it is struggling to supply the high pressure pump when you accelerate hard.
thanks mate  will look into that
