Front parking sensor replacement
Park assist failed today and code reader showing front right centre sensor as the issue.
Question is can it be replaced without removing under tray with it being the one below number plate?
Had another quick look and it looks like the two centre ones are clipped into black plastic surround which possible clips out of the grill underneath the licence plate.
Hopefully should be just case of unclipping plastic without breaking it and remove sensor
Plastic surround unclips from lower grill. Three clips, one each side and one on top. Unclip sensor, replace and refit.
