A3 8p sline front springs
Hi I recently bought a 2011 Audi A3 8P SLINE 3 door 1.6tdi. I was driving the last day and my front spring snapped, after searching to buy a new one I realised the SLINE came with lower and stiffer springs. The information sticker in my boot is scratched off so I don’t have anyway of knowing what spring would match, if anyone had the same issue or knows what brand springs match my car I would really appreciate it.
Regards,
Filip
Filip.
I can't answer your question, but whatever you fit you need to change both front springs for a matched pair. Not all springs of the same notional grade are identical, and in any case springs weaken as they age.
Thanks I know I’m definitely going to change both, non of the ones I look at for an sline seem to have the measurements so I could compare them to my ones, I’m planning to keep the car as is, I don’t want by accident to buy wrong ones for a standard a3 and the front of the car ends up sitting higher then in in the back.
Thanks
Thanks very much I have found the omes I needed now
