abs warning lights on
Hi all.
I have this A3 2010 1.9tdi
A red brake warning light has come up and the yellow traction and abs light on. My local garage plugged in and he was saying it's the abs pump/ module etc but he wasn't sure and couldn't narrow it down.  Will the car give me any codes some how ,any secret menus?  I had the same on my BMW once and had to replace the aluminium part on the abs pump which looks similar. I have a couple of OBD2 dongles but they are a bit unclear with what they show.  Anyone point me in the right direction?
As far as I recall those can also be the symptoms of an instrument cluster fault or an ECU fault. I don't know how you would pin down the actual problem except by replacement, which of course is a hugely expensive solution that could easily exceed the value of the car.
Does anyone know if I need to program a second hand abs pump and control module if I swapped one in ?
1 hour ago, Steve Q said:
Yes I believe you do.
Is there a particular part likely to be the cause?? The pump, the aluminium bit the plug in module?
Anyone in Bristol got vcds or vag scanners to help me diagnose in Bristol for some beers ?
