S5 4.2 engine removal
  • Replies 90
  • Views 21k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Teddynewson
    Teddynewson
    Well iv just put the back boxes on not properly or bolted up just too get the sound and I'm well happy  20240318_111145.mp4
  • Teddynewson
    Teddynewson
    Not been doing too much too her fixed the exhaust on properly and been looking for the red interior, last night had a good touch got a full set normally 600.00 to 1200.00, I won this for 136.00 yea to
  • Wow, you've made great progress. I need my engine out yet lol 😆
Posted Images
1 hour ago, Steve Q said:
Glad you got it built back up. How odd. Could the exhaust have moved?
Engine mounts ok?
I had too lower the box down more but the cats are on now
Busy day gearbox back up and sub frame, cats all bolted down and down pipes on, lead and plug on the starter motor, earth leads bolted on water pipes on, oil cooler on and alternator on, for some reason audi made the alternator + lead a black cable not red you can definitely mistake it for one of the earth leads as there 3
That's not good! Glad it didn't catch you out
I'm stuck power steering hose one on but can't see where the other part goes pulled the rack down again just incase it's hidden but nothing any ideas anyone
Never mined found it very top of the pump so engine mount off lift the engine a tad job done
20230708_140104.heic
well done you got there in the end.will it start and run ok now😁wheres muttley
Well it turns over nice by hand so we have too see on if she runs ok, back at work today so it be only Sundays to work on it or Oct when I'm off again
Got the new aircon radiator, was going too get a new rad but decided to clean and redue the old one came out nice found the oil cooler pipe damaged so new one on the way
  • 2 months later...
Not been on for a while been busy with work and late parts coming anyway starting to come together water and oil and so on in had a small water leak at the back thought hose so had to remove bits so I could see handy it was the drivers side more room to play with ends up being the bracket that goes to the upper timing cover water way to the water pipe on the side had a small crack in it
So got some parts rear lights and cables, but thought I'd work on the rear boot when it's shut won't open but it opens from inside the car by button and with the key iv took it apart seems I'm missing a cables 1 what ones and where do thay go as I can't see anything
Almost there 😎
  • 3 months later...
Not been on here or the car for a while been very busy with work and personal things but got back on it today and it's all together so hopefully I can turn her over tomorrow
41 minutes ago, Steve Q said:
Well done! You've done a great job 😊
Cheers Steve
Not been doing too much too her fixed the exhaust on properly and been looking for the red interior, last night had a good touch got a full set normally 600.00 to 1200.00, I won this for 136.00 yea totally stole it
What a bargain!
Be careful regarding air bag wiring though as connectors can vary.
As such, if conne tors are different the easiest option is to change the airbags abs wiring from your current seats to the new ones believe it or not.
37 minutes ago, Steve Q said:
What a bargain!
Yea that's correct Steve the lad took the plugs off this lot too put on his new set he got as thay where different so I'll be taking mine off the front seats and just swop them over
At least you're aware 🙂
Not sure if this is allowed if not please delete, so now iv got the new interior mine up for sale front seats are white, back seat and door cards are black all good condition no rips, and the rear lights 100.00
Yea it's fine to sell on here. I'd recommend doing a separate post under the for sale section.
Guessing you got your new seats installed ok?
