Coolant leak?
Definite slow coolant loss 2019 40TDI 48k miles (1/3 litre over 250 miles). No visible signs of an actual leak. Checked oil filler cap, normal. Is this a common issue? Been advised not to put any of the propietory radiator sealant liquids in. Car still under extended warranty, would this be covered please. Any help appreciated
Solved by fishphone
Hello Steve,
Common issue? - I would be sure not. Abnormal? -yes. This car should not use anything like that amount of coolant in a year, let alone 250 miles.
Simply get this investigated under your extended warranty, without any DIY investigation or fiddling. Warranty company?
Could be as simple as a faulty reservoir cap, or anything more serious from there.
I agree with Gareth, you need to be speaking to the warranty company asap. As Gareth has suggested it could be something as simple as the expansion tank cap not sealing properly.
  • Solution
Confirmed water pump, being replaced under warranty
  • 1 year later...
Steve, I have very similar problem car under extended warranty for life RAMP (Platinum)
How long did it took them to find the problem at the garage, how long did you wait to get this fixed? Was it covered under warranty I had to top up my car 0.3l every 300miles
Hello Leo,
Welcome and thanks for joining.
I think everyone’s experience in the same situations will be different, and likelihood of similarities of the outcome will be rare.
If it were mine, I would not be concerned with how long it took a garage in Lincolnshire to source the problem, since it is almost certain to differ from yours. Similar with the time to take action on the outcome.
Was it covered under warranty? - although it might have been with the OP’s warranty, it might not be with yours, and vice versa.
I would suggest you PM Steve and raise the questions direct with him, since he hasn’t returned to the forum for almost 18 months.
Perhaps you could keep us posted on the outcome Leo.
Message from RAMP
Good morning, Leo (this is only positive thing I got from them)
Heads up - "The pomp wasn't sized the timing belt didn't snap and the car didn't overheat"
Open my eyes and start reading this e mail ...
Thanks for your email
After looking through your claim i can see that it was declined due to the water pumps cause of failure being reported as seized
As you have stated, the water pump is a covered component, cause of failure dependent, in this case the garage stated as you have above that it is seized
please be advised that seizure is a listed exclusion in the terms and conditions of your plan - section 9 - see below:
9. EXCLUSIONS - The following are excluded from this Agreement
• Miscellaneous Items
Air conditioning recharging, ECU reflashes/upgrades, water ingress, exhaust system, auxiliary drive belts, brackets, mountings, tappings, supports, fixings and fastening devices, fuel tank and fuel lines, corrosion, seizure, rubber hoses, metal pipes or plastic pipes and unions, core plugs, bushes, decokes, foreign object damage and air bags.
This Platinum Plan does not cover any repairs in the following circumstances:
• Any parts which have not actually failed to perform their normal function, including but not limited to timing belts that are replaced as part of another job;
Unfortunately, as a result of the above your claim was declined
Fixed in Audi garage cost £1418 additional added for Audi health check £140
My recommendation is to Avoid RAMP warranty or if you have any warranty check what's actually covered or what is excluded.
Kind regards to all members
love my Audi car and how could I not pay to get it fixed ...
That's normal for all extended warranies and applies to almost any part that might be claimed for. I really don't understand why these worthless deceitful so-called warranties have not been made illegal. Their only purpose is to increase the salesman's salary without any risk of paying a penny to the customer.
Learn the lesson Leo, and never buy one again.
  • 4 weeks later...
Not to be captain hindsight here but this is due to lack of awareness from the garage in hand.
They could of instead of saying seized as a reason for failure could of said bearing failure.
Pump bearings fail which cause the seal to perish which causes loss of fluid which then works its way into the bearing casing and causes the seizing or binding of moving components from rust. the reason for failure is the aftermath of the initial failure which was the bearings; Which would have been covered under the extended warranty IF the mileage was under 100k or before the due date for camblet change mileage/time (this is common for most typical extended warranty policies).
I used to work in the motortrade and if you have someone looking out for the customer, which i always tried....READ the small print on their behalf.
This would be lazy service on their part or it may be the warranty rates for being paid for the part and labour were terrible and they just didnt want to be of service.
Edited by Optimus
