Weak heat
So I bought a new 2017 Audi A4 Technik S-Line literally today. It's my first day with it. And I've been driving all day and noticed that the heat from the car is really weak. I have it on high constantly and it's barely hot its more like worm. Any ideas or causes of this issue? I tried looking this issue up here and didn't find anything specific. Anything else even if you refer me back to the correct form. Thanks!
Solved by hamzaidlrbe
Welcome to the Audi Owners Club !
Good to have you onboard
Hello Hamza,
Is the car getting up to normal operating temperature on the gauge or display?
If so, you will need to check if both smaller bore rubber hoses from the heater matrix are of matching heat when the car is up to temperature, and the heater set to hot.
Are you able to return the car to the seller for them to sort out the issue?
Hello Hamza,
Thank you so much I appreciate it! The car is getting up to the correct temperature. I'm not losing any coolant and both the rubber hose are pretty warm (but not hot ) when the car is in operating temperature but they're the same temperature for both the hoses. I'm taking it back to the dealership next week to see but I was curious to ask to see if it's a small fix or a big problem.
1 hour ago, Steve Q said:
If bought from a dealer then they should fix the issue FOC in the first 30 days after purchase.  As you're entitled to a full refund within that time.
Yah I just called them to see and I'll probably bring it in Monday to see. Thanks!
Anything to do with the bag of crystals that was/still is added to the expansion tank, and can break up and find its way into the heater matrix?
I just looked that up and that seems possible. How would I be able to check ?
Checking if there is any remaining evidence of a bag or crystals, I guess would be a good place to start.
Having said that Hamza, you really don’t have to concern yourself about the cause or fixing of the problem. All you now have to do is to check it’s fixed ( properly) once the seller informs you it’s sorted.
Your right, I was over thinking it. Turns out it was the thermostat. They said they'll take care of replacing it and labour. All should be fixed by tomorrow. Thanks for everything!
Thanks Hamza,
This is confusing, rather than a solution to your issue, since you inform us that the car was getting up to the correct temperature. As such, I cannot see that the thermostat will be the suspect here (unless you didn’t inform us that it took a long time to get to normal operating temperature).
Not sure who marked this as a solution, but it may be rather premature if we are to study the evidence to date.
Is it possible to unmark! it ?
On 11/21/2023 at 4:04 AM, Magnet said:
Thanks Hamza,
Sorry for the confusion let me explain more.
so the car gets up to temperature quickly as expected. However when the heater is on and set to high it only blows cold/warm air. Even when set to High and the car is up to temperature. Even after driving for 20-30 minutes.
Now it blows hot air which is good within decent time but what I noticed is that the air is hotter on the driver side air vent compared to the one all the way on the right side of the passenger. And the rear ones blow more like warm air still. Is this normal?
Thanks Hamza, but I clearly understood your explanation of the symptoms from the start.
Where I have difficulty is understanding how the thermostat was considered to be the culprit, when the coolant got up to operating temperature ( and maintained that temperature) quickly enough.
My belief is that although they may have changed the thermostat, it has proved not to be the primary cause, and the problem was associated with some malfunction of the heat distribution system - now partially fixed.
From what you now describe, although better, is still not totally fixed.
No doubt you will be returning it, and perhaps you could keep us informed of the final outcome.
Yah you're right it's not a full on fix it's still on and off. Today I scanned the car used a VCDS and got the following two codes/faults under the HVAC module.
2 Faults Found
65543 - No Basic Setting
B2010 00 [00001000]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame
Fault Priority: 6
Fault Frequency: 1
Reset countec 108
Mileage: 1353 km
Date: 2023.11.28
Time: 21:44:44
First Run-ln
Circuit
Component
Klima Zone 3 H32 00
1048576- AC Compressor
B109E 13 [00001000] - Open
Freeze Frame
Fault Priority: 5
Fault Frequency:1
Reset counter: 108
Mileage: 135549 km
Date: 2023.11.28
Time: 21:45:34
Compressor shut-off condition: Compressor active: no shut-off condition is prese
Compressor current: actual value: 0.00 A
Compressor current: specified value: 0.00 A
Engine RPM:757 /min
Any ideas of what the issue?
13 hours ago, Magnet said:
Thanks Manza, so what are you interpreting from all that?
I think there is an open circuit in the Compressor that's leaving it open little bit. Then everytime there is more air coming it through driving its opening up more and letting more cold air out which mixes with the hot air the car is producing and I think that's why the AC is constantly warm for me never just hot. But we'll see once again, I'm taking it back to the dealer Friday.
  • Solution
Turns out the heater core needed to be flushed and now it works perfectly. According the mechanic when we replaced the thermostat we replaced the waterpump as well. He claims that the new waterpump was so good that it cleared the pipes and created a clog. Either way a heater core flush fixed the issue.
Thanks Hamza,
Mechanic…,
‘……new water pump was so good it cleared the pipe and created a clog’.
Sorry to be blunt, but what a load of rubbish!
Gareth
  • 2 months later...
I genuinely despair with Audi dealers. How and why would a new water pump be needed in this scenario?
The process of draining down probably did release a clog in the heater core which fixed the issue slightly. But if the pipe in is hot, then it’s not a water supply issue.
And why a new thermostat? Makes no sense at all.
Audi dealer service shops are pretty useless these days I have to say. My local one is full of kids fresh out of college, who just follow Audi’s online fix process, rather than diagnose anything.
