Fuel cap flap
Is the fuel cap flap supposed to be locked when I lock up the car? Locked the car and I could still open the fuel cap flap?!  if it's not lockable, is it possible to retrofit something to lock the cap when I lock the car?
Many thanks,
Alex
Hello Alex,
I believe it should lock. Possible cause - sticky solenoid plunger which moves to lock the cap. Open the flap, and look to the side of the inside recess to locate the plunger, then give it a squirt of WD40. Alternatively, you may need to remove the boot inner side covering and attack/ replace it from there.
I've had a look on the forum but I've not yet had the chance to look at the fuel cap recess! I will, soon and get back to you.
Faulty locking mechanism. They're replacing it on Monday. £130, not bad.
2 hours ago, Magnet said:
Not bad!-?
Hi Gareth considering the part is only about £25 makes you wonder if thats not bad for about an hours work, including tea.
I'm used to BMW level cost of repairs! 😛
Of course you are both right, and on reflection, the £130 charged wasn’t too bad. It’s just my mind would have been set on the very low cost resolution of a squirt of WD40 and a light tap on the offender.
It’s a Welsh thing of short arms and deep pockets!
Glad it’s fixed, and thanks for returning me to the true scene of economics?
Fixed. Car was in and out within 2 hours! Happy that it's now locked down.
