Pauline S.S. Posted July 5 Posted July 5 I've put a new sensor on and problem still there. How serious could this be? It's now booked into my Audi garage for a diagnostic.
Steve Q Posted July 6 Posted July 6 Keep us posted on how you get on. Stop/start issue could be caused by a failing battery. Could the replacement sensor be faulty?
Pauline S.S. Posted July 6 Author Posted July 6 It's only just (3 weeks ago) had a service and MOT. Nothing picked up then. I'll see what happens on Tuesday. Diagnostic is going to cost £150 before anything else. No choice really now than to go ahead with this. Many thanks Steve Q
cliffcoggin Posted July 6 Posted July 6 See this https://www.audiownersclub.com/forums/topic/13415-brake-servo-restricted/#comment-47826
Pauline S.S. Posted July 6 Author Posted July 6 Thank you cliffcoggin. Lots to read on that forum. I have read about the warnings on other forums which lead me to buying a sensor and having a go myself. The company I bought from: "partsforgermancars" has been mentioned here a few times. Perhaps the switch is faulty but we have no way of finding out.
cliffcoggin Posted July 6 Posted July 6 Even the Audi part is reputed to be unreliable so it's possible your new one is faulty, in which case it would be unwise to drive the car until it goes to a garage. However I think it is more likely to be a failing battery as Steve Q mentioned because of the stop/start fault. Let's hope the diagnosis shows something.
Steve Q Posted July 6 Posted July 6 Keep us posted on how you get on. Definitely don't drive it unless you really have to as long term it can damage the abs pump/module which is a big bill.
Pauline S.S. Posted July 6 Author Posted July 6 @Steve Q will do. Asked for a call tomorrow morning stating my worry about ABS. Thankfully I’ve not long to wait for the diagnosis / Tuesday.
Pauline S.S. Posted Tuesday at 04:13 PM Author Posted Tuesday at 04:13 PM Hi all. Thanks for the advice about the fault. Back from Audi garage. Fault found with replacement switch I bought. They’ve done a diagnostic check and fitted new one. All OK now. 2
Steve Q Posted yesterday at 03:22 AM Posted yesterday at 03:22 AM On 7/8/2025 at 5:13 PM, Pauline S.S. said: Hi all. Thanks for the advice about the fault. Back from Audi garage. Fault found with replacement switch I bought. They’ve done a diagnostic check and fitted new one. All OK now. Glad you got sorted 🙂
