Audrey03 Posted January 13, 2018 Share Posted January 13, 2018 Got this A6 and yes it's 2003 but why are all the bulbs blowing one by one? I've done both low beam, one full beam a brake light and now and indicator. Luckily I'm sat outside Halfords. Any ideas from seasoned Audi-istas?? Quote Link to comment Share on other sites More sharing options...
WPAWS Posted January 13, 2018 Share Posted January 13, 2018 if it was me i would first check my fuses and if all ok then get a garage to run some electrical tests Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 13, 2018 Share Posted January 13, 2018 Hi Chris, when my a6 suffered from a similar issue it had to be rewired for the headlight. halfords should be able to check the electrical system.for you :) Cheers Steve Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 13, 2018 Share Posted January 13, 2018 Hello Chris, There are a couple of things to go through here:- Have you had the actual operating voltage checked in this car? It should charge at around 14volts, but may just be putting in a higher voltage if the alternator/regulator is at fault. Of course, voltage much higher than 12v will adversely affect the bulb life. When you replace the bulbs, what quality replacements are you using? Some can be of very dubious quality and just don't last long. If the voltage is within reasonable limits then it might be worth investing a bit more by buying bulbs from VAG dealers. Fuses would really only be worth looking at if the lights don't work when the bulbs are known to be serviceable. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Audrey03 Posted January 13, 2018 Author Share Posted January 13, 2018 Yep it's bang on 14.2 v when running. I've replaced the gone bulbs with either Osram or Bosch. Either the bulbs are all similar age and starting to go or bad luck or a 're wore is looming. Nompun intended! Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 14, 2018 Share Posted January 14, 2018 Right then Chris, The answer isn't there then! If it were mine, I would now be monitoring the life of these new bulbs and see how they last. Now, did I read somewhere where quality makes (such as Osram?) were being faked, and were available on the Interweb at supposedly cheap and attractive prices? Might be worth simply getting any other ones direct from VAG dealer? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Audrey03 Posted January 14, 2018 Author Share Posted January 14, 2018 Hmmm I have heard if the fake bulbs but these were bought over the counter in Euro parts and Halfords so no fakes. I'm wondering if one bulb went and then another blew because I mishandled them somehow? Anyway I have Bosch and Osram spares so let's see how these last. No further blows yet. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 14, 2018 Share Posted January 14, 2018 14 minutes ago, Audrey03 said: Hmmm I have heard if the fake bulbs but these were bought over the counter in Euro parts and Halfords so no fakes. I'm wondering if one bulb went and then another blew because I mishandled them somehow? Anyway I have Bosch and Osram spares so let's see how these last. No further blows yet. Let's hope no more of them blow :) glad you're liking your a6 :) Quote Link to comment Share on other sites More sharing options...
Audrey03 Posted January 14, 2018 Author Share Posted January 14, 2018 I absolutely love it! Have you remapped yours? Mine goes well enough but I'm curious as to what difference it can make or if it's worth it? Quote Link to comment Share on other sites More sharing options...
