Various ABS/Tyre pressure/start & stop error messages
Leighvarnham
Hi all,
I started my A6 Allroad this morning, after having driven it the day before, and received a whole load of messages (see attached).
I stopped and started the car, and then it came up with 'Automatic Start/Stop: system fault - Function unavailable.
I arrived back home, left the car for a while, started it again, and it then came up with whole host of error messages again, and then reverted back to the 2nd error again.
Any ideas?
Thanks.
Hello Leigh,
Simple things first:- I would be getting the battery efficiency checked, together with the alternator output. Appreciating the car is only 3 years old, but these batteries get a hammering with stop/start systems. Recently experienced a total battery failure on an 18 month old Fiesta belonging to a friend. Such things were previously unheard of.
‘Christmas tree’ warning lights can often be as a result of low battery efficiency.
Thanks Gareth,
Quick question, as I can't find it in the manual nor online, but where is the battery? I've charged the battery via trickle charger, but lights still keep coming on, so need to change the battery, if I can find it first....
Thanks.
Hello Leigh,
‘.....so need to change the battery...’ Sorry but that is not what I would do.
I can only repeat my advice and get the battery and alternator efficiency checked. Please do not replace anything until proved to be at fault.
Not to lead you into unwarranted expense, my advice was aimed at eliminating - or otherwise - the battery and alternator as possible causes of your warning lights.
Location of the battery? Sorry, I’m not sure on your model, but could be under the seat?? Anyway, no need to worry about where it is, since if you are going to follow advice then the auto electrician will know where to find it.
Interesting about charging the battery. How did you trickle charge it if you don’t know where it is? Possibly via the cigarette lighter?? If so, not sure it is powered with the ignition off.
2 hours ago, Leighvarnham said:
Thanks Gareth,
Thanks.
Hi mate, sorry your no further forward with your fault. Your battery should be in the boot under the spare wheel (for future reference) but I agree with Gareth, get it checked first as they're not cheap to replace and a good possibility it's not the battery that's causing the fault.
I had a few lights come up on the dash recently and it turned out to be something completely different to what I would have thought. These modern day cars with all the electronics can be very difficult to fault find unless you know exactly what you're doing. The vcds lead/software can be very useful if you can get hold of one.
Good luck and please keep us all updated on your progress, we all like to help each other if possible.
Hi both,
Apart from asking my mobile mechanic to come round (at his normal hourly rates), to test the battery and alternator efficiency, how else could I achieve this? I know when my alternator went on my Lexus, my recovery company came around and had some tools to test the battery charge and alternator.
I've ordered a VCDS lead and will download the sofware, and test - hopefully over the weekend.
Thanks, Leigh.
Hello Leigh,
Yes, you can of course use you usual mobile mechanic, who’s rates you will know. You ask how you can get the battery and alternator checked and my interpretation of the question suggests - without paying your mechanics rates? Apologies if I’ve got that wrong, yet it seems you were prepared to buy a new battery without checking the current one, but would prefer not to pay to get yours tested.
If this were mine I would be seeking local recommendations for a trusted auto electrician and driving the car around to theirs so they can carryout the necessary tests for you. Personally, I would entrust this to an auto electrician rather than your mobile mechanic, not because there is anything difficult about these tests, but doing it as I suggests, puts you in touch with electrically experienced assistance, should the battery and alternator prove to be serviceable.
Hope this logic helps.
  • 3 weeks later...
Thanks all. I did get the below, while I was changing a few other options. Guessing the advice is still the same. Thanks.
Monday,15,April,2019,17:47:07:39322
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ4G1EN187359   License Plate: L33GHV
Mileage: 112522km-69917mi   Repair Order:
Gateway Installation List:  4G5 907 468 C
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
Monday,15,April,2019,18:07:58:39322
www.Ross-Tech.com
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 3B 42 44 46 52 53 56 5F
          62 6D 72 A9 C0
VIN: WAUZZZ4G1EN187359   Mileage: 112522km-69917miles
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0002
   Revision: 57H25---
   Coding: 322A403225260B020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
   ROD: EV_ECM30BTD_AU57.rod
   VCID: 34677F9D9FA2F5EA09-8060
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
                    Engine speed: 719.00 /min
                    Normed load value: 18.0 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 14.400 V
                    Unlearning counter according OBD: 40
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bits 0-7: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4699 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
   Part No SW: 4G0 927 158 L    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H18 1005
   Revision: --H18---
   Coding: 000001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMAL551211 002022
   ROD: EV_TCMAL551211_002_AU48.rod
   VCID: 377D48918ED41EF22C-8062
1 Fault Found:
13856 - Wheel-Speed Signal from ABS Control Module
          P1887 00 [039] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:17
                    Voltage terminal 30: 14.439 V
                    Control Module temperature: 88 °C
                    Transmission fluid temperature: 88 °C
                    Engine speed: 720 /min
                    Transmission input speed: 711.00 /min
                    Transmission output speed: 0.00 /min
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 0.00 km/h
Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Revision: --------    Serial number: --------------
   Coding: 49A7DF0592E5FBA0CB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   ROD: EV_ESPPremiAU57X_004_AU57.rod
   VCID: 3A7B51A5BDC6039AD3-806E
2 Faults Found:
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: BC
0393 - Front Right Wheel Speed Sensor
          C101B 01 [137] - Electrical Failure
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: C1
                    Uz: BC
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Revision: 00002001
   Coding: 01B93046000000000000
   VCID: 74E7BF9DD722B5EAC9-8020
   Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
   Component: J764 ELV MLB  H40 0046
   Serial number: 0214000134327012
No fault code found.
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AJ    HW: 4G0 820 043 AJ
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 21071400110924
   Coding: 3622000821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 67DDD8D19EF44E727C-8032
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0130
   Revision: 11012002    Serial number: 00000001558799
   Coding: 690000118134A7E0090500C000005F5F0F9D470827080201000004406000
   VCID: 6FEDB0F1BE04963234-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140625  H37 0080
   Serial number:         140707085750
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22903957
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AT    HW: 4G0 941 531 AT
   Component: E1 - LDS  H07 0044
   Serial number: 18 07 2014  00000388
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: B839CA37000000000001
Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061420401937
   Coding: 88C30C
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E9B689A03080C222-8024
Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JR01%
   Coding: 3032343631334E303537554A305234473053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod
   VCID: 3663459589DEE7FA37-8062
   Crash sensor for side airbag: driver side:
   Serial number: 3575HRB40652MKOSCP08
   Crash sensor for side airbag: front passenger side:
   Serial number: 3585HRB405N2MKOSB8HP
   Crash sensor for side airbag: rear: driver side:
   Serial number: 3515JRB400852M1AIH4X
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 3525JRB405P2SLKA9G52
   Crash sensor for front airbag: driver side:
   Serial number: 3554VRB401052MDQCOL1
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564VRB401252MDQRHA1
1 Fault Found:
1049350 - Databus
          U1123 00 [009] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:16
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140722000397
   Coding: 000035
   VCID: 306F738D63BAC9CA6D-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0010
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 66
                    Mileage: 112522 km
                    Time Indication: 0
                    Date: 2019.04.15
                    Time: 17:46:15
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G9 920 950 N    HW: 4G9 920 950 N
   Component: TDieGb    Nv  H58 0622
   Revision: 29131237    Serial number: 658170714596022
   Coding: 33A6200813412600010600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 3B7554A1B2FC3A92C8-806E
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 4G5 907 468 C    HW: 4G5 907 468 B
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001471427
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPkoUDS_001_AU57.rod
   VCID: 3561429994D8ECE23E-8060
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8041
   Serial number: 6928603903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140514000000000002F0
Address 34: Level Control (J197)       Labels:. 4G0-907-553.clb
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E536DF5718EDF3A7F-807A
1 Fault Found:
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8207VAHQ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
1 Fault Found:
10485793 - Operation of Inclination Display
          C113F F0 [008] - System Not Available
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 114
                    Reset counter: 106
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:17
                    DCU_Internal_DTC: A0 00 21
                    Ignition Cycle Count: 18427
                    DCU Temperature: 33 °C
                    Voltage terminal 30: 14.6 V
                    Voltage VBG 22: 2.5 V
                    Debug Data: FF 00 B7 00 01 00 00 27
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 479D3851F6346E725C-8012
Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0016774861
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 33657C819AACF2D210-8066
1 Fault Found:
3164944 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
                    Write only channel
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0340548478
   Coding: 013F0622A0B930008320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
   Component: TSG BF        H03 0507
   VCID: 46833555F13E777AA7-8012
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001143994
   ASAM Dataset: EV_ParkiBrake 001028
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D516AF97C88A42246-8078
1 Fault Found:
459776 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 112522 km
                    Date: 2019.04.15
                    Time: 17:46:15
                    Voltage terminal 30: 14.7 V
                    Internal Fault ID: 140
                    Vehicle speed: 0 km/h
                    Network management state: normal
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: static
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109G+0E7951390
   Coding: 010103020100000001
   VCID: 285F9BED5B6A810AB5-807C
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4G0 035 670 M    HW: 4G0 035 670 J
   Component: H-BNT-EU      H53 0814
   Revision: --------    Serial number: 190G%0EB008691
   Coding: 080101050003B1ED05808B3E00000003000001000200000000
   VCID: 2D516AF97488A42246-8078
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED0051TAV
   Subsystem 3 - Part No SW: 4G2 919 612 Q    HW: 4G2 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NGN000IM
   Subsystem 4 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49993E69E02098024A-801C
Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 191400812
   Coding: 097205C010
   ASAM Dataset: EV_HDSGAu572 001022
   ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H03 0507
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140623201046
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 2B5564E1429CAA1258-807E
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0007
   Serial number: 140523200665
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 24478FDD2F42656A99-8070
End-------------------------(Elapsed Time: 05:48)--------------------------
  • 2 months later...
Hi Charlie - my mechanic replaced the abs sensor, and it worked fine for a while, and now it's come back - intermittent. Which is a right pain as when he turned up last week - it was working.... Problem is that with all these warnings, I can't engage cruise control, and therefore I'm not driving it at the minute. If you have any joy. let me know please.
Thanks. Leigh.
Hello Leigh,
When you say your mechanic changed an abs sensor and it worked for a while, can you let us know what make sensor was used?
Many aftermarket sensors can behave in this fashion - being short lived. If not using a genuine VAG one, then the only alternative I would use would be Bosch.
Update: mechanic took a look and found that another piece of the loom had broken. He hasn't replaced it - just stripped and solded where it was broken. All working fine. Apparently, as Audi decided to put bends in the wire, due to heat and light, these then have a tendency to break.
My view is that if when you turn the wheels. and the warnings come on the dashboard, it's a broken wire/sensor. HTH. Leigh.
  • 3 months later...
Hello Leigh,
Sorry if I’ve missed something here, but are you talking the whole wiring loom within the car, or a section of your it?
If (somewhat unbelievably) you are talking the complete wiring loom for the car, then surely your local Audi dealer will provide you with the loom/part number. Same if part of the wiring loom.
Hello Leigh,
Thanks for clarifying that.
I could be wrong, but I doubt if anyone on here would have greater experience of Audi part numbers than the Audi dealer themselves.
I’m still left wondering why you want details of the actual part number rather than just the part itself, which must be available (or not)  via. the dealer on description rather than quoting them the part number.
Perhaps you could enlighten us.
  • 1 month later...
I have contacted Audi UK as the dealer wasn’t replying. In short, they have both said the same thing - and Audi UK’s response is below......
“Thank you for your email.
We do not personally provide part numbers; instead we see any queries as an opportunity to create business for the Centres within our Audi Network.
I hope you understand our position regarding this, and our effort to create a relationship with individuals who drive our vehicles.
I’m sorry I’d be unable to assist you any further on this occasion.
Please get in touch if I can help with something else”
Hello Leigh,
Understandable reply from Audi.
Any chance you can update the forum with an answer to the question I raised on 23/11/19 - why do you want the part number rather than the part?
Sorry Gareth,
I was going to see whether there was an OEM version or secondhand one available.
And ideally as it’s an easy install, I was going to install it myself.
Thanks. Leigh.
  • 1 year later...
hi mate! i have a Audi A6 2017 67 plate and have the same errors in dash and when i turn the engine and move the sttering to the right everything pops up. ive change the abs sensor [ genuine part from TPS UK ] and nothing...today ive change the ball bearings on wheel [magnet] and stil the same. im desperate. did you resolve it ? let me know please
Hello guys! I own a Audi A6 2017 (67 plate) and i have some problems with it. The problem is when i turn right on the Dash comes out : Esc/abs: fault , hold assis unavailable, tyre pressure fault , audi adaptive light fault , brake servo system fault , hold assist unavailable , main beam unvailable.
I went to the mechanic and put the tester on it and said about the Abs Module and Abs sensor. Ive change the sensor woth genuine part ( TPS UK ) and same problem…today i went and check it at electromecanic to see and he said their is the ball bearings wheel the magnet is not good anymore… ive change that also with genuine part (TPS UK ) and no results 😶
i put the tester again and gave me this errors: C101B14 and U111300
to be honest im desperate as i dont know what it has. Can somebody who had the same problem can help me ? Please ! Thank you very much !
Regards
Regards
When was the battery last changed? A failing battery can though up odd electrical faults. Might be worth getting it checked.
