Audi a4 b7 2.0 tdi 2006 will audi a6 engine mount fit
What engine mounts will fit
Hi you really should start surfing the net for part numbers there are several sites that do parts catalogues for your model, try Zap 7 or failing that your local car parts centre will be able to help via the REG/VIN, TRY Carparts in motion.
Thanks steve
I've not long picked up a set of mounts for mine. Got them from Autodoc.. circa £50 each plus postage.
Ian
Thanks Ian mine has the sensor on it
Can't guarantee that yours will be on there, mine doesn't have the sensors. Worth having a look though, a very crude search just now found they do appear to stock them. You're looking at upward of £100, maybe closer to £200 each.
Ian
