A3Etron Posted April 18, 2023 Share Posted April 18, 2023 Hi - new on here! My MMI unit on my A3 e-tron (2018) is not working properly and I have been advised my Audi main dealer it needs replacing at insane expense! Looking for advice - would it be possible to fit a second hand MMI unit and then have this reprogrammed so that it would work with my vehicle? Issue is that it starts up with 'initialising' screen then after 30 seconds shuts down, and the cycle then repeats again every couple of minutes. Tried a hard reset from inside the car using the centre console buttons but didn't sort the issue. Thanks! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 18, 2023 Share Posted April 18, 2023 Yep a second hand unit can be coded to the car. Alternatively you could look at an aftermarket apple car play/android auto unit.聽 1 Quote Link to comment Share on other sites More sharing options...
A3Etron Posted April 19, 2023 Author Share Posted April 19, 2023 (edited) Thanks Steve, really appreciate your prompt response! Apart from the inconveience of not having any music/satnav, it is going to be a bigger issue come MOT time as I also had a tyre changed (puncture) and although it is now fine, I can't initialise the tyre pressures as this all done via the MMI computer so showing as a warning on the dash that I can't update.聽 Next question...is the recoding of a replacement MMI unit sort of thing a 'local' specialist could do or would this have to be done by an Audi main dealer? Edited April 19, 2023 by A3Etron Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 20, 2023 Share Posted April 20, 2023 I don't think the tyre pressure warning light is a failure but happily proven otherwise.聽 Yep it can be done by a retrofitter such as Audi retrofits or autologics. Or try a local vag retrofitter local to you.聽 Quote Link to comment Share on other sites More sharing options...
A3Etron Posted April 20, 2023 Author Share Posted April 20, 2023 Thanks again Steve!聽 Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 20, 2023 Share Posted April 20, 2023 8 hours ago, A3Etron said: Thanks again Steve!聽 No probs at all 馃檪 please keep us posted on how you get on 馃檪 1 Quote Link to comment Share on other sites More sharing options...
