Fuel problem
image.thumb.png.41f1723ca049f33a06eadf6b69c011f6.pngMy car won’t start put my little tester on and this is what it said I haven’t a clue it’s Christmas Eve Eve and I need my car so no garages open any help or advice would be really appreciated thanks
The could be caused by a faulty injector, high pressure fuel pump, fuel pressure regulator or purge valve.
Is the car misfiring?
Have you cleared the fault and tried to start it?
No it’s not misfiring but the heater plug sign was flashing it wouldn’t clear thanks
No probs at all. I'd definitely look at the items I've described. Ideally a more advanced scanner might show so e more codes.
When you cleared the code could you drive normally? Or did it come back?
It just came back and wouldn’t start but the day before the power wasn’t there it was like in limp mode the garage I use isn’t open till after the new year I’ll just have to wait but thanks for the help it’s given me something to think about thanks
Will do 👍
  • 10 months later...
Hi David,
On my C4, the glow plug light would flash to indicate low battery voltage, which, in itself, can cause a raft of other issues. How old is your battery?
Mike🤔
