So how it started (no pun intended). Drove the RS4 for about 400 miles on and off and no dramas really.
1st problem - Starter partially engaged a few times (horrible noise) then started fine.
2nd Problem - Squealing poly belt on tick over (still working but annoying.)
decided to take the car off the road for a few months and do both jobs.
Anyone looking to do any of these jobs be aware it a little more work then your average.
1) poly belt,
jack car up and take belly pan etc off.
Then you need to slide the front of the car forward, (Audi S4 4.2l alternator belt and tensioner replacement DIY by Edge Motors)
Fog lights out
Bumper off
watch the video! easy job but make sure you have a long pole or breaker bar to take tension off belt.
NEXT
Starter motor, (what a !Removed! of a job) Audi RS4 B7 - 4.2 V8 - Starter Motor change
One of the engine mounts Allen bolts near the exhaust is a pain but doable.
Stripped and cleaned starter motor. engaging shaft was all carboned up, cleaned and lubed and works like a dream out of the car.
heat shield was put back on but maybe not as well as it was when i took it off due to its age. (Might be a problem)
So poly belt installed and works fine
Starter motor works every time .............................
When the car is warm after a run it wont start. Clutch pedal down (audible click) and no joy, Leave the car for 10/15 mins to cool down starts straight away! Assuming the heat shield may be making the starter solenoid overheat and not sure if it tells the car not to start if its to hot?
Also if car now left locked up over night it drains the battery.
1) Charged battery and it hold charge fine. leave it disconnected over night and didnt lose any charge
2) did a parasitic draw check. car unlocked and drivers door open, drawing about 4 milli amps
removed all relays from under steering wheel and no change to draw.
car running battery doesnt drop so alternator is charging.
3) Once locked and left it drops to 1.6 milliamps
is this bad?
my thoughts are before i did starter and poly belt it was fine so its something i have done.
Any ideas what may be drawing?
Bad earth from starter?
Bad cables from starter?
Heat shield hot starter sending signal?
bad earth or something not on properly attached?
any help would be appreciated.
Plan on getting the car back on axle stands and getting access to the starter again, check all the plugs and leads
wrap exhaust near the starter and try and make a better deal with the heatshield.
Hopefully i notice something!
Great advice and great jobs done. Sorry to hear you've got a power drain. Keep us posted on how you get on.
Could it be the imobiliser?
Hello David,
Seems like you have your mA in a twist.
Power consumption when the car has fully shut down (possibly in excess of 30 mins after being locked) should be around 50 ish mA, so 1.6 ma must be wrong.
My guess is you are talking amp figures here rather than mA.
Try disconnecting the alternator output plug - might be discharging through a faulty diode.
Regards,
perfect thanks, I've jacked her back up and found a slightly loose starter earth but surely that wouldn't be it. i will disconnect the alternator plug and check the draw. ill keep you updated. i will have closer look at the multi meter to get the amps in the correct power. seen as i've only fiddled with the starter i assumed it would be that but alternator could be a shout.ill update tomorrow once ive had a fiddle about.
