Audi a3 1.8tfsi car trying to stall itself and reving itself
Hi all please please please can someone help me I really don’t wanna sell this car but I recently bought a 2009 Audi a3 1.8tfsi and it occasionally starts stalling and revving by its self I have replaced the throttle body and the pedal with the throttle position sensors but still no job iv also has a play with the inlet manifold and still nothing please can someone help me the epc light used to come on with check engine but now no more light since wipes the codes but it still does the problem
Solved by Rhys1234
Thank you so much for your reply My grandad has his own workshop so we’ve tried and tried still coming up with throttle Acuator or something but yeah it’s been remapped before my ownership
Thank you mate
Hiya buddy nothing about maf is coming up on obd
No I havnt where is it located ? Would you know?
 Ot sure to be honest. But if the fault code is that then I'd look to inspect it and replace it.
Alright thank you
Will do thanks buddy
  • 2 months later...
On 7/25/2025 at 6:16 PM, cliffcoggin said:
Remapping has made it much harder to diagnose the faults. If a proper diagnosis does not lead to a fix, all I can suggest is to restore the original map and hope for the best.
Any update here?
Ok cliff calm down!
  • Solution
Hiya, Yesh I did manage to fix it completed forgot about this forum though and it ended up being an aftermarket throttle body that was the problem garage put on an oem one, coded it in and bee running a dream for a while now sorry for late reply
Thanks Rhys, I’ll pass this onto my mechanic just in case. Nightmare trying to figure this stuff out.
Cannot see the point in using an A3 petrol throttle body as a bench mark against an A6 diesel ultra, your throttle body is on the inlet manifold at the end right next to the EGR and both are water cooled, his vehicle on the other hand has a throttle boy under the inlet manifold which has no water cooling and runs on a completely different system, ergo the chances of you having a cheap aftermarket unit fitted are non existent as all the throttle bodies for the Ultra system whatever make have been used as O.E. at some point and my one only failed at around 200k.
Yeah no worries however like Stevey says They are 2 different cars with 2 different engines running off 2 different fuels so there solutions will not likely be the same as there could be a million issues in between the two of them and my car/engine hates aftermarket part's but yeah I hope you find the problem, good luck mate 👊👍
Hi Steve
Ive Literally commented on the very few posts that coincided with similar issues I'm having with my car. Trying to figure it out here as mine showing zero faults with plugged into computer. Feel free to pass on your expertise
21 hours ago, Lolos A6 said:
Hi Steve
Hi simply couldn't comment on your situation as I seem to remember you quoting it had a remap therefore the the variables problem wise are immense as it has been taken out of the manufacturers as built scope of fault register unless you have someone who understands live data you are stuck the only clue I can give you is that if this occurred after a cam belt change, the cam timing could well be out or the crank position sensor is shot which could be checked on live data but the belt is mechanical which would involve stripping it back and checking the timing marks are spot on.
Its a !Removed! nightmare! Anytime I drive over a ramp it acts up also which leads me to believe its a loose connection somewhere but where 🙈.
Hoping for some kind of miracle at this stage, could be anything.
Thanks for feedback
Thanks for feedback
Hi if you get the car test driven whilst plugged in they should in theory drive over a ramp and if all the ignition and injection feeds are on graph and logging, you should then be able to watch it when its returned to see which circuits bumped when you crossed the ramp.
