2011 A1 TDi RPM automatically increases
2011 A1 1.6 TDi, I am presuming the RPM should automatically increase when moving off (anti stall I think). My daughters car doesn't increase the RPM and is quite easy to stall. There are no fault codes and no lights on, has anyone had this problem or have any idea what might be wrong?
Manual 5 speed.
Hi its quite normal for the revs to increase as you lift the clutch could be a faulty clutch position sensor.
Thank you Steve, I'll get the VCDS plugged in and have a look for it.
Ignore me I miss read the post
Edited by jonny1983ie
