A6 AllRoad suspension - help…
A few months ago on a morning my A6 would be sat very low on the rear passenger corner, when starting up, it  would raise to the correct height, I ignored the issue foolishly until I got an amber and then red warning light on the dash… and it would no longer correct the problem. I took it to the garage who replaced the rear passenger airbag, the compressor (worn out from over working), (non original Audi) and the air manifold. The car was returned but the next morning on the way to work the amber, then red warning light (suspension too low) both came on, at the end of the day the rear drivers side was completely down.  I took it to the garage and they replaced the drivers side airbag too.  Now the cars suspension keeps dropping (to the ground) every couple of journeys, no pattern as in, more people in the car or type of driving or distance, sometimes it’s the rear that drops  and now sometimes it’s the front that drops, on checking the fuse for the compressor (40 amp in boot) will have blown, replace the fuse and wait, and the ride height eventually returns (may take several restarts of the engine)! The garage has swapped the manifold back to the original one, same fault still exists. If it is the compressor and an electrical fault, why is it that different corners/ends drop? Do the new airbags need specifically calibrated via VAGCoM?Any ideas would be gratefully appreciated.
Thank you for your replying Steve Q, Just checking with the garage for the fault codes and will add later on.
2 hours ago, cliffcoggin said:
From what I have read on this forum the level sensors are prone to failure, which might explain why different corners are dropping at random.
I’ve had one of them replaced so far too! 🫤
So an update, the car has continued to blow fuses and the suspension is dropping, sometimes the front, sometimes the rear…
I have used VCDS to clear all codes, the car drove ok yesterday 8th (although a few codes registered) but then. Today 9th suspension warning light came on at 8am and blew the fuse at 4.35pm.
level 34 of the read out (Level Control) identifies C11AF F0 - leak detected🫣 any ideas.
I will add the whole VCDS file below
K80 PDH 9-01-26.txt
