Light on door card?
Realist
What’s the LED on the drivers door card for, thought it was the alarm but mind don’t flash or am I barking up the wrong tree.
Edited by Realist
Sorry to hear you are not getting a free-of-charge answer to your question within 19hrs Brian. It would possibly have helped if you had offered more detail of where this LED is on your driver door - not the one which indicates the door are locked, I don’t suppose-?
Anyway, good luck with finding a quick answer on your alternative forum. Perhaps you could try adding a ‘please’ on the post to them - as I thought was common place in our neck of the woods.
Well all I’m after is for someone to say yes this is the alarm LED or aftermarket I have no idea hence the question.
Then I would ask other questions but no issue at all.
Regards.
