Brake servo restricted
I have just managed to get the last 1 from Nottingham Audi going to replace later today fingers crossed all goes well 👍🤞🏼
  • Replies 717
  • Views 469.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
Hi Steve, the only fault that was on the history was tyre pressure, nothing on brakes/ABS. I read another post that also reported this was the case. The garage owner however did not give up and contacted this support team and they confirmed this is normal and the pressure sensor should be replaced before the car is driven again, they are hopeful the ABS unit has not been damaged.
Just picked it up fingers crossed 🤞🏼
Marc, did it fix the problem? My car goes in tomorrow.
Yes the brake servo is a okay now but I have the ABS light on now but the car drives and stops fine. I took it to a mechanic that I know he gave it a diagnostic test he can switch that of as it needs to go to Audi to switch it off. I love the car but thinking about part exchanging it sadly
Hi Marc.
Did Audi manage to switch it off? I have the same problem and they said it can't be cleared and the ABS control unit and hydraulic part need replacing. I also had sent it to audi Nottingham.
Dev
39 minutes ago, DevQ7 said:
Hi Marc.
Dev
Hello no I haven’t taken it to the main dealership yet. I have a very busy week will speak to them next week. If they can’t help the car will be sold I will buy another Audi
Will not buy
I thought the ABS units could be refurbished at a fraction on a new unit or am I wrong.
Just picked up my car from the garage after having the pressure sensor replaced, all appear to be fine. I really think this should be a recall item as it is a known fault and being brakes a safety issue. Does anyone know how we can bring it to the attention of Audi, any contacts etc as the main dealers do not appear to be interested.
Glad it's sorted. Might be worth sending an email to Audi customer services in Milton Keynes. Or contact watchdog etc.
Hi i have Audi 161 20.tdi.with same problem. Brake severo  coming up. Hade it in Audi workshop today and said it well cost 3000 euro to fix is this wrong .
Hi if it’s just the brake servo it is an easy fix cost me £80 and it took me 5 minutes to change very easy
Brake pressure servo sensor
I was told by an ex-Audi mechanic that it could but when he sent mine off to be fixed they returned it saying it couldn't and that a new one would be needed at a cost of £3k. Thats when i took it to Audi and they confirmed that it needed replacing.
I agree that they really need to look into this as its such a vital component of the car that has this fundamental error. Its good/lucky for most of the people on here, that they managed to get the sensor replaced in time but for the ABS unit to be irreparable after driving a few miles is a flawed design fault and needs to be investigated.
Email the customer services on customer.services@audi.co.uk and the director on andrew.doyle@audi.co.uk
I have emailed Audi but we need all those that have had this failure to contact Audi. They have replied saying they will investigate.
Hello Peter,
It will be interesting to hear of your progress.
Re. recalls, it would be helpful to know what VAG’s worldwide actions has been in terms of this, since it’s reasonable to suspect that this might vary according to what may be considered acceptable actions in certain countries.
USA may be a good place to start your homework.
Can you put the address on here so we can all email it should be a stronger voice please
The address was on a previous post but it is customer services on customer.services@audi.co.uk and the UK director on andrew.doyle@audi.co.uk
Thanks I will email later this afternoon thanks
I've sent separate emails to both those, and even dropped Top Gear a message to see if they'd run a story on it. I'm not holding my breath there, but no harm in asking.
I have just had a phone call from Andrew Doyle's Executive Customer Relations Manager to say they are not aware of any issues with the sensor or the ABS braking system and as I had the sensor replaced at an independent garage and not a Audi main dealer they can not investigate it. I explained that I went to an independent garage as the Main Dealer, that has been looking after the car, could not book it in until mid July. I said I am concerned that the sensor could fail again, luckily this time I was local, next time it might be difference. My confidence level with the car is now low but hopefully I will be proved wrong as I like the car. Thanks to the members that advised me to get the sensor changed before I damaged the ABS unit.
I've sent an email to both emails too. I'm waiting for a reply saying similar that they've not heard of it and sensor wasn't changed at audi etc etc but let's see. Next step will be trading standards / Watchdog.
Some good info on here thanks, though fear I might have found it too late 😞.
After a recent service, I had a sporadic 'Brake Servo: restricted. You can continue driving. Please contact workshop' message. I intended to call and discuss with the dealer, but it disappeared and I saw no obvious change to braking.
This message then recently returned and I noticed a light clicking/grinding sound when applying the break at very low speeds (crawling in traffic/slowing for expected traffic light changes/parking), before I've had chance to book in for inspection following it's return, it's now switched over to 'Brakes: fault. Safely stop vehicle' and the red warning, there are no other lights, no ABS light etc.
I'm calling the dealership shortly, but with what I've seen in the thread I'm fearful that I've progressed through the 'You can continue driving......' -> '......therefore knackering the ABS' trap 😞
Particularly galling, as I made the switch to an Audi on reputation (and that I've always wanted one) but also necessity, when my Ford Focus trashed it's engine due to a 'known fault' with the Ecoboost cooling system and temperature reporting... Effectively wrecking it's own head gasket/engine one fateful ten minute drive. At 20k miles and feeling still almost brand new, I wasn't expecting a fault of the likely costs if my fears are correct.
Hi Foxy.
The whole situation is a disgrace and needs exposed. I hope it works out for you. You aren’t still with Audi Assist by any chance?
Roddy.
