Hi so my car has just turned 4 years old and it’s been to Audi for its 2nd MOT. It passed but had an advisory for Offside Rear Lower Coil spring mounting corroded but not seriously weakened!
They want £320 to change it ! £18 part which is a rubber mount with a aluminium strengthening plate mounded into it that corrodes! Great idea not .
So has anyone else had any issues yet?
Hi,
I had the same problem on my 2017 a4 allroad last year,
same place, o/s/r lower, I had mine replaced at an independent
v w garage  at just over £100.
p.s. my brother, who has the identical car had his go as well on
the o/s/r/    seems funny it is always the o/s/r. that goes.
Never had a issue with my 2017 A5 and my father in law has that now , does seem very poor for an Audi just turned 4 year old to have issues like this already, cars only done 28k !
 I have found a guy with YouTube that found the same problem when changing his spring on a A4 funny enough
Hi its quite a common problem mostly the rubber bit rotting out but if I were you I would take heed of the term not seriously weakened, get under the back clean the alloy bit with a small wire brush and then give it a coat of Waxoyl that will keep the rot at bay for years, did mine when I first got it 2019 and they were still good four years later.
Waxoyl’s  a brilliant idea Stevey 👍 think I’m going to try and change them first then apply the waxoyl
  • 1 year later...
Posted (edited)
Just Checked mine after reading this ,glad I did off side one is rotten
Edited by Jim Ridley
Waxoil won't stop the corrosion. The alloy insert is there to strengthen the rubber suspension seat. It corrodes from the inside. Leave it and you risk the spring breaking. Easier to replace on a 2WD car. On quattro, you can remove lower shock mount. You need a piston jack to extend lower trailing arm down. Worst case scenario, loosen subframe bolt a few turns too. No need to undo the eccentric bolt either.
